intake noise on 98 12 valve
Old 05-25-2008 | 08:24 AM
ChrisM55's Avatar
On my brothers 12 valve w/a 0 plate 4" straight pipe and bhaf after he does a hard accel. run and lets off the throttle the intake will kinda go pop pop pop real fast. Is this some kind of overboost or backpressure?? We have the wastegate elbow in also.
Chris
Old 05-25-2008 | 11:41 AM
bob4x4's Avatar
Sounds like what is referred to as turbo bark...........don't lift so fast under high boost conditions.
Bob
Old 05-26-2008 | 10:57 AM
ChrisM55's Avatar
I will let him know
Thanks
Chris
Old 05-26-2008 | 11:17 AM
pokapotato's Avatar
I am always intersted in why things do what they do. Maybe this will help. Under high load you have pressurized with compressed air everything from the outlet of the compressor housing through the air-to-air cooler into the engine. When you let off the throttle quickly there is no more exhuast heat to drive the the turbo. All that boost you were just building now wants to take the path of least resistance and come back through the turbo and out the intake. As it comes back through the turbo it is trying to slow the wheel down very fast. Thus the barking noise. Not such a great thing for turbos. I have seen large industrial turbos shear the wheel off the shaft when this happens.
Old 05-28-2008 | 08:00 AM
turbos10's Avatar
Yup, chuffing or bark sounds kindof cool, but it can cause your engine to have compressor wheel for lunch.
ShowMe06
27
01-04-2008 12:47 PM
natlchamp2k4
03-13-2007 06:47 AM
BA05'CTD
01-07-2007 04:08 PM
dodgezilla04
07-01-2006 02:28 AM
Bobcat698
09-24-2005 11:51 AM
