Instructions for RV275 Injector Installation?
I've searched high and low and can't find a decent set of instructions for installing new injectors. Can someone post a link? Thanks.
one thing to remember is there are two bolts per injector to hold them down, you only need to pull the one closest to you the other is a slotted hole and a real pain to get to. when you put the valve cover back on make sure the gasket gets seated in the rear as you tighten it, as it is a prime place for a leak. be sure to get all the clamps back in place and tight as they can leak to the insde of the manifold. have no fear it is a piece of cake.
http://www.dodgeram.org/tech/dsl/ISB...or_replace.htm Those are the ones I used. They helped a lot.
shortydodge
07-31-2007 04:40 PM
