installing valve springs with head on engine
I want to install 60lb springs before the motor goes in to the truck. figured it would be easier to do on the shop floor than in the truck. Any one done it this way ? If so what did you use to compress the valve springs? I was thinking to just bring the pistons up to TDC for each cly to keep the valves from droping to low.
genos garage has the valve spring compressor for under $30. worked good for me. all in all its a pretty easy job. just use a magnet to remove the retainers so they dont fall into the pushrod holles. cover any holes up also.
I used a little compressor that KD tools sells when the engine was in the truck and it wasn't to bad (5-6 were a little tight but...) as you said just put the piston to the top and away you go.
Yep they make little spring compressors for use with the head on the engine.
On gas engines I have a little adapter that screws into the spark plug thread. Has a air nipple on it. It allows me to put air to the cylinder to keep the valves up. Works like a charm for changing seals or springs.
I picked up the springs and a 4k GSK today the 4k was the same price as a 3k when they brought out the package it said 4gsk on it and I asked if it was the right one they said yes all they have is the 4k they just pull the small spring if you want the 3k so I asked if they were the same price and they were so I said give me the other springs too then.So I geuss I will be going 4k nobody else ever drives the truck but me any way.
92smokin blacky
07-18-2011 08:48 AM
rock crawler
36
12-29-2008 09:47 PM
53 willys
23
05-19-2008 06:14 PM
rebel5422
04-11-2008 04:41 PM
dsljunkie
14
10-10-2003 09:29 AM
