Installing Nozzles???
i was told the process in installing injectors or nozzles inquires releasing all the pressure in the fuel rail.. what is this process?? can anyone help?? thank alot - Jared
2000 sport 2500 5 speed... 24 valve, of course... so the installation of the nozzles on the injectors and the injectors back in the truck is fairly easy?? i'm very mechanically inclined, just not soo much w/ diesels yet... thanks, Jared
Registered
Registered
JSCumms, your going to need a 900 dollar clutch and a 1500 dollar turbo to get all the power out of the juice and nozzes.
Also, not to be down on you or your truck, but story goes that if you bomb your truck the vp will go out. Ive replaced 5. (three on my truck, one on my buddys, and one on my dads)
And whats your fp? the stock lp system will not keep up with the jammers and juice. id throw in a holley blue or somthing along those lines if i were you
i know.. i know.. i already talked to a guy from South Bend... so thats lined up and as far a fuel pressure, i cant remember what it runs now off hand... i do have a gauge for it... but i knew i'd need a fass fuel system or something like that... turbo should be ok, but it'll run hott... this i know haha we shall see anyways.. thanks !
Registered
Phat shaft 62/12 would be good for you, or anything 62mm, exhaust housing depends on your needs. Smaller for spoolup and larger for more top end cooling.
Jamie
Jamie
southernsmoker
04-08-2004 02:19 PM
Amish hauler
02-22-2004 09:42 PM
