installing gauges????
Old 06-18-2007 | 01:30 AM
kenny1987's Avatar
Exclamation installing gauges????
can someone help me to install these dang things boost and pyro gauges
Old 06-18-2007 | 01:31 AM
kenny1987's Avatar
and fule press. gauge
Old 06-18-2007 | 08:42 AM
Dinner's Avatar
What would you like to know? Where the adapters drill/thread into the engine? A lot of people usually just drill and tap the Boost Gauge into the intake horn, and run the hosing accordingly. Drilling and tapping for the fitting. Fuel Pressure you can get a taped banjo bolt. So it reads the pressure as the fuel is entering the VP. And the pyro, a lot of guys drill pre-turbo so it reads the temp before it hits the turbo. They drill into the exhaust manifold, trying to keep as many shavings as possible from not falling into the manifold. Then tap the whole to the appropriate threads. Then take a vacuum and try to suck all the shavings that you can up fro inside the manifold.
Hope this helps, if not others will pitch in
Kman9090
29
12-06-2007 07:43 PM
coontz0473
17
09-22-2006 04:52 PM
Duckman1993
09-12-2006 08:50 PM
dncoy
08-09-2004 08:26 AM
WHIFF
15
06-11-2003 12:35 AM
