Installing a fuel pressure guage
Old 06-22-2005 | 07:18 AM
atch's Avatar
When installing the fuel pressure guage with an isolator, is it reccomended to use a needle valve? If so, where is the best place to install it? Just before the isolator or ri9ght at the point that it is T'd into the fuel line?
Thanx in advance
atch
Old 06-22-2005 | 08:15 AM
crobtex's Avatar
I'm thinking that the isolator does the same thing as the needle valve. One is suppose to keep fuel from getting to the cab and the other to turn it off if it does.
Old 06-22-2005 | 08:43 AM
Walt L's Avatar
In this case the needle valve works as a snubber. A snubber stops the hard pulsations made by the injection pump. These pulsations actualy vibrate the isolator diafram which in turn makes the gauge needle not work smoothly, shortening the life of your gauge. You can mount it in either place. Most prefer where you Tee into your fuel ilne so you can stop flow to your gauge if you ever need to replace/fix it.
sabo21
08-18-2009 06:38 AM
mountainman
07-22-2009 10:14 PM
ScottMt02
07-27-2007 08:04 PM
jgiachino
16
07-11-2007 08:33 PM
bigragu
01-24-2006 12:16 PM
Quick Reply: Installing a fuel pressure guage
