Installing EGR Front Brakes
Went ahead and ordered the full front kit for my truck and it's supposed to be here Fri. I'm pretty good with working on the truck but I've never really messed with the brakes before. If one of you could give me a little direction as to what to expect it would be much appreciated. Being a '99, the rotors don't just slide off like later years....are they a pain to get off? Any assistance on anything that could teach me something would definately help out.
Thanks,
Adam
Thanks,
Adam
DTR Advertiser
I dont have egr brakes but I did change rotors on a 98 4wd recently. The hub bearing has to be driven off to remove the rotors. The hub is usually stuck pretty good to the spindle. I removed the 4 bolts from behind the spindle, then reinstalled 2 of them about 4 turns, put the socket on the bolt then found a punch that fit in the 1/2"drive opening, and beat it loose with a 3lb maul from behind. Once the hub/rotor is loose you have to drive the wheel studs out to remove the rotor. When you put the bearing hub back in clean it good and install antisieze. Makes me glad I have a 00 with slip on rotors. Tim
Well, I have had bearing hubs seized in the knuckles so bad that the only thing that would yank them out was a 25lb slide hammer - mind you, it does make short work of them........if you can free them up by banging on the hub bolts, that is great but I would consider that very lucky from my experience.......I don't bother with any other method other than the slide hammer anymore.
CTD NUT, you're in salt country. On a truck that's lived out of salt belt the bearing usually comes right off the axle with just a dead blow hammer to the back of the rotor while turning it.
Idaho Guy
16
02-12-2020 11:15 AM
MOJO1
08-04-2009 06:28 PM
