Installing a #10 and Second Guessing
Old 06-25-2005 | 01:59 PM
satburn's Avatar
Does my location and gov arm look ok for a #10?
Old 06-25-2005 | 02:06 PM
bmoeller's Avatar
Looks about the same as mine. Works just fine. Don't usually need to re-adjust the arm for a #10.
Old 06-25-2005 | 02:07 PM
satburn's Avatar
thx. I shall continue wrenching then...
Old 06-25-2005 | 02:09 PM
DZLPWR's Avatar
From what i can see , it looks okay. Right on the nose or maybe a hair higher. Just so it doesnt go under the plate. Watch your EGT gauge
Old 06-25-2005 | 03:57 PM
satburn's Avatar
Holy Crap!!! I can see my 30lb ISSPro Boost Gauge is basically worthless now.....
That's purely amazing! One question: With my ol' stocker plate slid forward and the AFC adjust in, the transition between off-boost and on-boost wasn't very noticable. Now when it get's to 1800 RPM it's just BAM!, redline on the tach and the boost gauge. Is there anything I can do to help the lowend out?
Old 06-26-2005 | 11:37 AM
Dshiftff's Avatar
When I hear about sliding the plate full forward, from what I see on the pics, its the adjusment on the plate where the slots are where those 2 screws are going into? By the looks of it, that plate is full forward? Also, about the arm adjustment mentioned, is there a screw to adjust this or what. Thanks...
Old 06-26-2005 | 12:09 PM
satburn's Avatar
Yes, it's not quite all the way forward, but we're very, very close...
Also, about the arm adjustment mentioned, is there a screw to adjust this or what. Thanks... ?
Yes, there's a cap on the end of your AFC housing, it faces your firewall that has a screw to adjust it. There's instructions here:
Click Me!
Old 06-26-2005 | 02:29 PM
Dshiftff's Avatar
Thanks for that link. exactly what I was looking for.
Old 06-26-2005 | 07:30 PM
bmoeller's Avatar
Not the rear of the AFC housing. It is on the governor housing, on the rear backend.
Old 06-26-2005 | 07:36 PM
bmoeller's Avatar
Guess why I have a 60, instead of a 30, now.
Originally posted by satburn That's purely amazing! One question: With my ol' stocker plate slid forward and the AFC adjust in, the transition between off-boost and on-boost wasn't very noticable. Now when it get's to 1800 RPM it's just BAM!, redline on the tach and the boost gauge. Is there anything I can do to help the lowend out? [/B]
It is the profile of the plate. If you notice, the stocker has a nose in the middle. The 10 doesn't.
Is the AFC housing slid full forward also?
The ramp on the bottom of the profile on the 10 is limiting the fuel on the bottom end. Want more fuel on the bottom, take the stock plate, and turn it into a 0 plate.
Rickcher
02-18-2011 10:52 PM
SINGLESTACK
05-31-2009 02:59 PM
kdbvulcan
14
05-05-2009 08:56 AM
65pacecar
11-23-2007 09:21 PM
JKM
10-27-2005 04:36 PM
Quick Reply: Installing a #10 and Second Guessing
