Installed Juice w/Attitude, couple questions...
![Question](https://www.dieseltruckresource.com/forums/images/icons/icon5.gif)
Just got my new Juice w/Attitude installed today. Everything is working fine except for the boost guage on the Attitude.
I didn't install the boost elbow as I have a Banks wastegate on it. I was pushing 34-35 lbs of boost according to my old guage which I took out with the old Banks box.
Also I'm wondering if the Map sensor could be bad. I did get a code P0237 on it a few weeks ago, cleared it and it hasn't come back.
When I took it for a test drive after getting everything installed, the highest boost I saw on the Attitude was 7 psi. I know that's not right...
Any ideas?
Any ideas?
Go into 'Alerts' and check to see what your alerts are set too. I think.. That if you have your alerts set to off, it will still defuel if you hit any set alert point, it just wont beep at you when you hit it and start defueling.
Thats the only thing I can think of off the top of my head.
I have the alerts on, boost alert is set at 35. The backdown percentage is 0 and you can tell it's fueling and has boost, the guage just isn't showing any.
I am wondering about the MAP sensor, trying to find info on how to test it.
Rams2500, dont mean to burst your bubble but adding the J/A wont build your boost like that..
Olddodgeowner has a HX-35 turbo, Not sure what year model etc truck you have but if your only hittin 19lbs I'd guess a 2000-02 auto that would have the HY-35 turbo.
The fueling from the juice will get you up to 21 lbs ish, but no more unless you do something with your waste gate. J-Hook, turnbuckle, clamp the hose shut.
Thanks ok. I'm just looking to wake up a stock truck and have heard good things about edge. I do have a 99 auto. I'm pretty new to the performance section. Thanks for the info.
5.0 Mustang Man
10-21-2008 02:50 PM
04Red3500
12-14-2006 12:05 PM
1882
08-25-2006 07:35 AM
1tuffdiesel
03-10-2006 03:20 AM
RamWheelsBy4
23
02-17-2005 02:15 AM
