Installed the comp
Installed the comp
I Just installed the Edge Comp today and oh yeah baby. It felt like the first time I drove my mustang after putting a supercharger on it, but for far less money. Anyways I just wanted to say thanks fellas because if it weren't for this site I would not have known about the comp.
Thanks Corey
Thanks Corey
You have guages to go with that 120rwhp right you might want to get some I dont see them in your sig. That comp box can cook turbos and run your vp44 Dry Pyro and fuel pressure are the most important nice to have boost and trans temp as well
Yep, Sorry haven't updated my sig yet but just installed guages earlier in the week. Pyro "before turbo, cause you guys said", boost and fuel "post filter and again cause you guys said". Next will be a 4inch exhaust and tranny guage and yes in the hotline cause you guys said.
p.s. what is the difference between the ETC and ETH motors?
Thanks again
Thanks again
Might be...depends on condition of your tranny. IF your planning to do it soon..play away. If you need it to last a while, I would stay with EZ setting.
RJ
RJ
EZ setting numero uno? What a waste. Crank it up to at least 4 on the EZ setting. That way you get a nice puff of smoke when you leave a light. Oh, and your tranny should be able to hold 4 on the EZ setting. Mine held it just fine. It's when I became stupid and hooked up the wire and put it on 5x5 that did mine in.
Mn-Corey
Was Assuming you did full install. Have you pierced the wire?
Answer to your question -
ETH = Order code for (2001+) High Output Engines
ETC = Order code for Standard Output Engine
RJ
RJ
Sorry, haven't been around. I live in forest lake, about 45min north of the twin cities. Yes, I hooked up the pump wire . What is the ez setting 4? I thought the 1 setting was the ez and the rest were above that?
SUb levels
JB
CTD2001
84
08-13-2006 10:33 PM
James Lucas
14
08-29-2003 11:24 AM
hellotbone
07-12-2003 12:58 AM
hellotbone
18
05-16-2003 04:40 PM
