installed #10 plate, No power??
#32
Take your shutoff solenoid off, and wire the arm up that it pulls up on the pump. It may not be getting full fuel right there. If it doesent pull the arm up all the way it can cut the fuel back a lot.
Eric
Eric
#33
YA its coming up as far as it can.
My throttle cable broke last night, where is a cheap place to get one? dealer wants 83.00 YES 83 bucks!
#34
Dont know where a cheap place to get one would be, but that could be part of your problem for sure. Your truck should be smoking pretty hard until the turbo spools. Mine would lay down a pretty good cloud with just a #5 plate. You did LOOSEN the starwheel didnt you? Didnt tighten it by accident? Also, the boost line that goes into the back of the pump should be checked for leaks and stuff. If that boost line has a hole in it, it will cause your truck to be way low on power. The rubber diaphram inside the AFC housing could also be worn out, and not working correctly, which can cause a severe lack of power. These 12 valves are pretty simple for the most part. If something isnt right, it is probably a leak somewhere or an adjustment. Im not saying it is going to take off like jet engine because of a fuel plate, but mine gained a good 100hp which is very very noticeable. let us know how the new throttle linkage does.
Eric
Eric
#35
Thank you cumminsdriver! your vary helpfull.
My truck gives some smoke till it hits about 1800 or so. above that its min. if any at wide open throttle. It was noticeable for sure but not even close to my 99 with just a edge programer set on level 5. IT smokes! stock injecters too!
Anyways ill kepp you updated. Maybe one day ill be able to assist your problem! till thin thank you!
West Coast
07-01-2007 02:32 PM
Rockcrawler
14
06-23-2005 11:40 AM
banks twinram
02-05-2005 10:38 AM
