Installed #0 plate and gauges yesterday!!! GRINNING
Old 05-11-2008, 05:34 PM
SilverHoss99's Avatar
I got everything in the truck finally and wow did it make it super fast, but It falls on its face at 18psi and I cant get anymore boost than that so any help would be appriciated thought maybe blocking the waste gate. I am not sure though so I am looking for some help with this.
Old 05-11-2008, 05:44 PM
Willy91's Avatar
block the wastegate. how do your temps look?
Old 05-11-2008, 09:57 PM
temps not even touching 1100 I need to know how to block my wastegate
Old 05-11-2008, 11:15 PM
DTR question asker
dieselfuelonly's Avatar
You've got a 0 plate in a truck with a 215 pump and are only seeing 1100*? I'm impressed. Where is your pyrometer probe located?
Old 05-11-2008, 11:44 PM
kelownadiesel's Avatar
get the governor springs too and yes you have to use a boost elbow or disable the wastegate .Oddly your temps are very low for only 18psi burning that fuel.Where did you tap for the pyro?The gsk will wake it up alot more than you would think.I have a o plate and 4k kit ,thats it and I can bury my pyro easily at 40 psi
Old 05-12-2008, 08:07 AM
pro puller's Avatar
Check your governor arm & make sure its not going under the plate.With a 215 pump & stock turbo you should be able to hit 1500 & 35 lb of boost.
Kurt
Old 05-12-2008, 07:59 PM
Pyro is in the a lil off center towards rear 3 cylinders on the exhaust manifold pre turbo. I am curious just unplugging the wastegate line from the AFC and plugging it up would that work? I am still wondering bout stopping the wastegate? How do you do it?
Old 05-12-2008, 08:23 PM
a77ssii's Avatar
I can only dream about 1100. #0 plate, star wheel all the way and waste gate blocked I can easily pull 30#'s and 1600+. Last time I had the boat hooked up (3500#'s) I had to fight to keep it at 1400.
Old 05-13-2008, 04:49 AM
plvaulter06's Avatar
only 18lbs... you just need to block the line to the waste gate. And ya there is definatly something funning going on, with a #0 plate and your 215 pump, your motor should be swimming in fuel and about as hot as a firecracker at only 18psi. Is it making clouds of black smoke at WOT?
Old 05-13-2008, 05:43 AM
AlpineRAM's Avatar
Well, if the AFC works it will limit the amount of fuel the pump delivers- it should keep the arm from touching the plate even.
I'd suggest verifying the pyro and the boost gauge, tweaking the AFC and a 3K GSK.
It should be much hotter then-- and ask for a 2nd turbo to get enough air in
AlpineRAM
Old 05-13-2008, 11:21 AM
ratsun's Avatar
AlpineRAM
Bingo
Full time Valet mode
Old 05-13-2008, 07:41 PM
Im going to clamp off the AFC line totally right at the pump and see what happens my boost line for the guage is plumbed in up by the firewall into the line from the wastegate to the AFC housing so hoppefully that will still work. The gauges seem to be working porperly and no I am not getting a ton of fuel cause he smoke is more of a haze everywhere before when I had the AFC gutted it would roll smoke like crazy with no power no I got power till about 30MPH and it falls on it faces very little smoke.
Old 05-13-2008, 08:12 PM
Willy91's Avatar
won't clamping the line going to the afc cause your foot to not move? You need to block the wastegate not afc signal.
Old 05-16-2008, 06:56 PM
ok so there is one line from my wastegate it runs to the back of my turbo my wastegate is attached to the back for the turbo houseing by like a 8" bolt it looks like so Im confused as what to block? which line am I blocking?
Old 05-16-2008, 07:28 PM
Tate's Avatar
Disconnect the signal line to your wastegate, and plug it. There should be a rubber line near the actuator, thats where I'd disconnect it. If you leave it open, you'll have a boost leak, and your AFC still won't move properly.
Quick Reply: Installed #0 plate and gauges yesterday!!! GRINNING
