Installation Pictures Of Dynatrac Hubs.
Old 05-22-2008 | 08:35 AM
  #31
bsp's Avatar
bsp
Thanks for sharing Ron, I've been considering this for some time. I read somewhere that a guy installed a grease fitting for the wheel bearings on his truck, does that look like an option with this kit? I remember on the older Power Wagons I used to own it was nice to be able to grease the bearings once in a while. I haven't had mine apart yet so I don't know what all is in there. Nice pics!........Brad
Old 05-22-2008 | 09:16 AM
  #32
rpausewang's Avatar
I think you could drill and tap the hub between the bearings so you could add grease. On your power wagon where were the grease zirks located?
Old 05-22-2008 | 11:26 AM
  #33
bsp's Avatar
bsp
When you pulled the front wheel off there was a hole in the rotor beside one of the wheel studs that you used to get a socket in there to loosen the bolts to take off the hub/wheels bearings. There was also a grease fitting in there, you just had to spin the rotor and find it with a light. Been along time since I 've had to work on one,......back in the oilfeild days (southeastern Ohio)........Brad
turbo hoss
34
01-02-2010 06:10 PM
TreeFarm
29
02-22-2008 04:32 PM
Big Smoky
14
03-02-2007 07:50 AM
njmaier
06-24-2006 06:58 PM
white94c
Off Road / 4x4
06-19-2006 02:08 PM
