Input wanted on DTT Torque Converter, and others.
I need something real reliable and do a good job with big loads. One of the tranny guys around here only uses DTT TC's. I just would like some input about them, and any other reputable ones. Thanks!
Valve Body, sorry.
Valve body: hydraulic control center that receives pressurised fluid from a main pump operated by the fluid coupling/torque converter. The pressure coming from this pump is regulated and used to run a network of spring-loaded valves, check ***** and servo pistons. The valves use the pump pressure and the pressure from a centrifugal governor on the output side (as well as hydraulic signals from the range selector valves and the throttle valve or modulator) to control which ratio is selected on the gearset; as the car and engine change speed, the difference between the pressures changes, causing different sets of valves to open and close. The hydraulic pressure controlled by these valves drives the various clutch and brake band actuators, thereby controlling the operation of the planetary gearset to select the optimum gear ratio for the current operating conditions. However, in many modern automatic transmissions, the valves are controlled by electro-mechanical servos which are controlled by the Engine Management System or a separate transmission controller.
lniemeyer2
10-24-2012 12:11 PM
Bersaglieri
01-09-2008 01:38 AM
chevota01
09-21-2007 08:00 AM
