Injectors Or Vp44?
Old 09-10-2005 | 12:23 AM
mx572000's Avatar
Injectors Or Vp44?
I have a 2000 Cummins with an edge comp,AFE,4" MBRP exhaust, boost and egt guages, and a Vulcan big line-LP relocation kit. On settings 4 and 5 at about 23lbs of boost the truck stutters and surges, 1-3 are fine.Only happens in higher rpm's. The truck has about 95000 miles on it and I was wondering if the injectors might be dirty or if my pump is going out. Any help would be great! Thanks, Justin
Old 09-10-2005 | 07:47 AM
j-fox's Avatar
What is your fuel pressure under load?
Any codes?
Old 09-10-2005 | 02:15 PM
mx572000's Avatar
I'm not sure what the fuel pressure is under load, I haven't got a guage yet. I checked all the codes with the drb and nothing came up.
Old 09-10-2005 | 02:23 PM
smokindog's Avatar
The VP$$ is more likely the culprit and just because you don't have a code doesn't mean the VP$$ isn't dying.
You need to know what your FP is. If you replace the VP and don't have a FP gauge you'll destroy the new one just the same.
Get a FP gauge installed and then try to diagnose your problem.
Erska
17
03-06-2009 10:52 PM
KRB
05-20-2007 07:20 PM
Smokin'02
02-25-2007 09:39 PM
Timmay2
25
02-12-2006 02:00 AM
BIGOKIE
07-21-2004 06:53 PM
