injectors?super b single
3's are 100hp, I have the 4's which are 125's. I just dynod at 462 hp. I would buy the Jammers again for cost and performance increase. I just bought the tips and installed in my stock bodies.
On a hard pull the EGT's will get upwards of 1650. Cruising on the highway about 7-8. Spools really fast and does what I need for now. I went with the Super B just in case I decide to run twins in the future. Its a good base to build from.
Launching at 22-23 pounds and 60fts are 1.84-1.86. Everyone I see can't believe it's only a Super B, but it is. Like I said the combo just seems to work. And for the record, it is high 8.6's
how much hp does your quad adrenaline give you.if I put jammer3 super b single and j/with ad will I be close to the 400 hp range?
I personally would in NO way recommend you putting in 100's, way to small for a 64, that's better suited for a 62, if that. I think most of the guys that complain about high egt's running 100-125 hp injectors with a 64 is because of injector quality. "Dirty" injectors make unnecessary heat, get a quality injector, like a mach 4 or 4.X and you will be happy. If you tow forget the 64 and get a 62.
All just opinion,
Alex
All just opinion,
Alex
All just opinion,
Alex
All just opinion,
Alex
