injectors with stock turbo???
i think my injectors are going out, im haveing trouble figering it out right now but thats what all its looking like. i dont want to go back stock but i cant afford a new turbo. i was thinking about the f1 mach 1.6, i looking for towing and mpgs. ill be looking to get a new turbo later and dont want to change the injectors agen. ideas?
ya im down on power, no there are no codes, everyone keeps giving me symptoms for the IP and they dont match whats going on, i think im leading diesel into my oil, wich when you havent changed injectors ushuly meens its getting by one of the seals in the injector, i think that means i cant do something easy like the jammers
i ran mach 4.5s with the stock turbo and with my chip set to 2x3 egts were fine and not a ton of smoke. theres room to grow like when i put on my htt ss62. personally i like the way it ran with bigger sticks and less chip.
well as u can see iv only got the XZT+, i dont care if it smokes probibly be agenced my cause if it did, like i said looking for good towing performance and mpg. i figer whatever gaine i get over that will do me for the offraoding and little bit of raceing i do
waiting for a reply on some gages i want to buy, ill have them in well before i get the injectors in. reading another post the mach 1.6s sound like the bigest i would want to go with, just the other weekend i had a laod of about 12k lbs i took over to the beach and back.
ya thats y im getting them, im waiting to see if the oil level is going up, i think it is and that will tell me alot there too, i marked my dip stick and am driving it now waiting to check it agen. it im right then is the injectors
Try this trick. Get a paper towel and lay it out flat. Take your dip stick out and let it drip on the paper towel. Watch the drop and see if it spreads out. If there is fuel in the oil, a lighter colored ring should spead out from the dark oil drop. If it just stays in a dark drop then there should not be any fuel in the oil.
