Injectors Or Nozzles???????
Old 12-18-2007 | 04:27 PM
chali84's Avatar
im sure someone has asked but my searching didnt really help
i keep seeing high performance nozzles for sale that claim will produce as much horspower as some of the big injectors do for vp44 trucks
i also see that they cost much less than a whole injector kit
is this true or can somebody give me a pros and cons of that route or just point me in the right direction for info
thanks again
Old 12-18-2007 | 04:51 PM
John Faughn's Avatar
The tips are part of the deal , pop it testing & springs , so they all are balanced .
Old 12-18-2007 | 04:55 PM
haloman's Avatar
Nozzles are generally regarded as overrated smokier ways to get more HP where as full injectors are cleaner and closer if not over the advertised HP.
Old 12-18-2007 | 04:57 PM
Jetpilot's Avatar
Injectors......
Old 12-18-2007 | 06:39 PM
wurkenman's Avatar
I run the Jammer Stg4 nozzles on my stock bodies. I would do it again in a heart beat. I paid 240 delivered to my door and for the money, you can't beat them. Mine dont smoke a lot unless I'm full on the throttle with the box turned up. I did it just to see what kind of change it made in my truck. Now I know if I want different injectors I can change and maybe upgrade and I know the money might be well spent. For a 240 dollar test it is one of the best upgrades I have made so far. Took about 2.5 hours to install and I have never been inside the motor before this point.
Old 12-19-2007 | 05:20 PM
chali84's Avatar
now when you guys say smokey are you talkin like general motor running and emits somwhat of a haze
i dont really mind the smokey part (not a big concern were i live)
dont get me wrong im all for injectors but it just seems like its worth trying out for under 300 bucks as were the "listed" equal injector is probly 1000 bucks plus core charges.
I am not made of money but i am still really into the diesel perfromance arena so im trying to maximize on a budget.
I know how the cheap route in most cases ends up being a bad idea.
I just wasnt really sure if the nozzles were a bunch of hype
but i think they might be worth trying out.
Old 12-19-2007 | 05:24 PM
chali84's Avatar
im still pretty new at this and i dont know what the hell you mean by that
sorry
could you lay it down slower for a nebie please
Old 12-19-2007 | 05:45 PM
pmtg's Avatar
your injectors 'pop' open at a certain pressure, cummins has a spec as to where it should be.
when you replace your nozzles you should have your newly 'rebuilt' injector (nozzle assembled to stock body) 'pop' tested to make sure they 'pop' open at the recommended pressure. if they dont, the spring could be worn or shimming may be necessary.
Old 12-19-2007 | 06:00 PM
chali84's Avatar
where would one go to do this kind of test.
ANd i hope you dont say a dealer cuase that would be gay
cummins certified mech. shop or somthing?
Old 12-19-2007 | 06:22 PM
seabee's Avatar
your local fuel pump shop should be able to pop test the injectors for you
Old 12-19-2007 | 06:46 PM
chali84's Avatar
thank you much
Old 12-19-2007 | 06:54 PM
chali84's Avatar
im gonna look into this and ill let you all know what i end up doing
WestTexasRam
10-04-2006 04:38 PM
WhiteRamDiesel
03-08-2006 03:00 PM
singleturnout
13
01-18-2006 07:14 PM
killfast1
40
07-07-2005 05:15 PM
macaw
02-10-2005 01:38 PM
