injectors or nozzels???
Im wanting to do some injectors or nozzels, but i dont know which i should do...the nozzels are way cheaper, but i dont wanna cheap out and get sumthin thats no good...i was looking at some 110 hp ones from BD Diesel...has anyone used them or know anything about them? what would you all reccomend for my truck???? would 100 hp or so be good, or too much for what i have??? also, am i going to lose fuel pressure by adding them? if so, any idea how much??
I would get a Smarty before injectors....especially if you tow. Smarty is by far the strongest "low end" grunt performance enhancer on the market today. If you don't plan on upgrading your turbo....add a set of RV275 injectors & you will have a awesome towing truck that can still get up & go. My brother has a Smarty & RV275 injectors....his truck really pulls a trailer well & runs like a raped ape when empty. Just my $.02
I tow about 10,000-15,000 a few times a week..but it might end up being more often then that...so im wanting to get it setup mainly for towing....i can get a turbo if i really need to...i dont wanna just through money away on stuff i can do without..i figured on upgraded sumday in the future, just hated to have to do it all at once,,esp since ill prob be needing a clutch soon., but i do want to be able to tow 10,000-15,000 without much trouble and without getting too hot...so
have you checked out the towing and hauling forum? this guy has stage 3's and a superchips...https://www.dieseltruckresource.com/...d.php?t=151889
You will love the stage 3 nozzles. I run my truck with my SuperChips when empty but when pulling I turn off the SC and just run the injectors. So far, EGT's have'nt really been an issue. The highest I've had them was last weekend while I was pulling a 6% grade and hit 1200. All I did was back out of it a little and they came right down. EGT's are very manageable with the stage 3's.
Most go with the III's if they are towing.. and will be using a stock turbo... If its heavy.. just watch your EGT's.. and may have to drop the EZ to a lower setting... On the comp box I usually tow on level 1.. if its heavy.. I'll turn the box off...
You'll be happy with what you ordered.. usually those that get the 1,2 or 4's.. usually wish they would have gone bigger.. never seem to hear that from those that went with the 3's or 5's... (Jammers.)
Bryan
Bryan
