injectors and fuel plates?
Old 07-09-2003 | 11:06 AM
1320's Avatar
Why is it that they don t neccesarily go together? Or do they?<br><br>What injectors would you recommend (as little smoke as acheivable) and plate.....for <br><br>12valve with hybred yardly turbo, bhaf, 4&quot; exhuast....5speed<br><br>I see stage 5 (etc...) 370's, marine 370's, dd3's? whats the deal? Shoot for 500 rwhp....<br><br><br>
Old 07-09-2003 | 01:06 PM
yrusoslow2's Avatar
Re:injectors and fuel plates?
What year is your truck. If you are looking for as little smoke as possible but still want good performance then I would say go with the 300's. As far as which plate goes with the injectors I do not have much experience with that but I would say a #6 plate adjusted right and 300's would perform rather well with your setup. If you want to make 500 rwhp then you are going to have to deal with some smoke. Hope someone else chimes in with some more info on the plates for you.<br>Justin
Old 07-09-2003 | 03:35 PM
gunracer1's Avatar
o plate, some 370s or better and a lot of turbo, you should be able to get 500hp.
Muskys TD
02-20-2007 11:26 PM
0053500ctd
08-25-2005 11:45 PM
eng208
05-31-2005 12:38 AM
gunracer1
12-13-2004 03:52 AM
Eskimo
10-18-2004 09:57 PM
Quick Reply: injectors and fuel plates?
