Injectors and boost fooler
How much hp/boost will bosch 275 rv injectors with a boost fooler give on a 98.5 24v 5 speed. Would this be more reliable than a fueling box, and better for the motor? What egt's does this run on a hard pull? Thanks
Pike
I'm not sure about the 275s but my DD Jammer 2s (85hp) and the comp turned off is around 27-28 and I find it runs cooler?(dont understand why) I love the power from the injectors alone and very seldom turn the comp on, also milage is up over 50kms per tank after the first couple of tanks(gotta try all the new power ) I would recommend injectors first and you may not even want or need a box. Just my .02 worth
ratsun
ratsun
Killdmycobra
11-12-2010 05:15 PM
SS1156
11-02-2008 10:25 PM
Rollin' Smoke
23
06-26-2007 09:04 PM
SSV1761982
08-30-2005 10:28 PM
GTSDave
07-08-2005 09:06 AM
