injectors
injectors
what is the biggest injectors you recommend for a daily driver i was thinking of 100hp or maybe 125hp i do plan on upgrading turbo at the same time or shortly after. I was planning on running with the programmer off for most of the time thats why i figured on the 125hp cause thats the highest setting for the juice so it would be like driving around with the programmer turned up all the way which i do sometimes anyway.
I dont think your driving around at peak Hp all the time even though your box is turned up all the way. injectors are a great investment IMO stay away from nozzles get a good set 125 or 150 if they are a good injector will be smooth good power to combo once you do get a turbo. they may be hot egt wise with a stock turbo and using your box, but you can adjust the box. I'm happy with my mach injectors but there are some other good ones out there also.
darrenG
06-21-2005 10:24 PM
