Which Injectors?
Which Injectors?
I've got a pretty much stock 01 mods r in my sig i want to get some injectors but i dont want anything that will make my truck fail miserably and explode lol and if it makes a difference i have the hy35 turbo and i dont have the money to replace it so opinons would be nice
Thanks,
Derrick
Thanks,
Derrick
With your HY-35 and a stock auto tranny, you need to be careful.
I would go with {url=http://www.f1diesel.com/injectors24.html]F-1, Mach 1.6 injectors[/url]. They are not the cheapest but they are the best.
Reason for Mach 1.6's - they will give you the lowest EGT's for a 100 hp set. Drive it carefully. I know an auto with more than a 60 hp chip would be too much, but injectors are less invasive, IMO.
If money is really tight, a set of Bosch 275's will give you a small boost in hp (maybe 40 hp) and be fun for a while.
Good Luck
RJ
Good Luck
RJ
Bradleysram
19
05-12-2009 08:36 AM
