Injectors?
Injectors?
I keep thinking that I should upgrade my stock injectors.... I would like to buy the right injector the first time. If I buy a DDP 150hp or similar, will I be nothing but smokey, or can I controll smoke with going easy on the pedal? I see Vulcan has the Fireball injectors for a very attractive price, anyone have any experience with them? I have a superchip, so I believe I will have to either get a boost fooler or upgrade the electronics... probably to an adrenaline. From what I have read, I think I would rather have bigger injectors and be able to turn down the power with electronics if needed. Also can't help but think I may build a set of twins down the road.
Alan
Alan
look at getting Mach 4 injectors, they are top notch. They will be drivable with your box turned down and when you get twins you will love them. I plan on doing the same thing
darrenG
06-21-2005 10:24 PM
