Which Injectors?
Which Injectors?
I'm wanting about a 150 injector. All my mods are in my sig.
I would like to know the drivability, how hot, and how clean the injectors are.
Can I tow with them with a stock turbo?
Drivability-ok unless its wet
Temps-probably a little hot (*especially towing and at WOT) unless you stick on a different turbo
Cleanliness-depends on which brand and manufacturer you go with when buying your injectors
You will also need a fuel system upgarde to provide enough fuel for your sticks. If you fail to do this, kiss your IP goodbye!
Bradleysram
19
05-12-2009 08:36 AM
