injectors??????
Old 12-09-2007 | 06:36 PM
yung cummmins's Avatar
injectors??????
can i just put like some 50 hp injectors on my basically stock truck
or do i need other mods and if so how hard is it to get these installed
Old 12-09-2007 | 06:49 PM
RJ285's Avatar
Most would steer you towords a chip if your only going for an extra 50 hp. Chips you can turn off, injectors are always on. Chips are also easier to install.
Old 12-09-2007 | 06:51 PM
im gonna do the 120 hp xzillaraider to its just a thought
Old 12-09-2007 | 07:25 PM
C2O's Avatar
C2O
why not just make more holes in your dash????
Old 12-09-2007 | 07:27 PM
C2O's Avatar
C2O
you can add any injectors anytime, as long as you can support them with enough air. depending on which injectors you get you wont know how you stock turbo will supply the air until you try them out.
Old 12-09-2007 | 09:24 PM
Tate's Avatar
RV275's are around 40hp, and pretty cheap (around $300 for the set).
Old 12-09-2007 | 09:55 PM
saab9k's Avatar
Have the rv injectors and edge comp, usualy leave edge off, the rv injectors are fine for city driving, towing
Old 12-10-2007 | 12:13 PM
where can i find "RV injectors" at
Old 12-10-2007 | 02:37 PM
ib516's Avatar
ebay, or here from one of the sponsors...usually around $250 (low) to $300 (high/average). I just bought and had a set installed. I paid $295 + shipping.
Old 12-10-2007 | 04:23 PM
Fishin2Deep4U's Avatar
Injectors are arguably the best kind of power to have. They are linear and respond to throttle position.
To get the most out of any set of injectors, you will want at the bare minimum some kind of box that adds timing. This will help with the EGTs and milage.
One thing is for sure, even with the sticks I run, I usually run the box on timing only and it's a flat pleasure to drive. In order to drive the same HP level with no injectors or small ones, I would have to have the box on kill. Not as much fun to drive for me.
Dave
Old 12-10-2007 | 04:42 PM
heykw's Avatar
I would install some jammer 5's best bang for the buck
Old 12-10-2007 | 08:16 PM
MikeyM's Avatar
Dave, what size injectors are you running?
Old 12-10-2007 | 08:30 PM
Mach 6.
Dave
Old 12-10-2007 | 11:42 PM
ddt's Avatar
ddt
Talk to Eric at Vulcan Performance. He has RV275's for $249 including shipping.
KRB
05-20-2007 07:20 PM
GSP
12-11-2005 01:20 PM
W.F.O.
11-03-2005 11:33 AM
darrenG
06-21-2005 11:24 PM
BIGOKIE
07-21-2004 06:53 PM
Quick Reply: injectors??????
