which Injectors
Old 07-04-2007 | 11:30 AM
RSwood's Avatar
which Injectors
I have a 96 ram CTD, I already have an straight pipe exhaust, afe intake, and a #10 plate. I'm going to change Injectors, the truck will be used for drivng around town and towing. I'm just wondering which Injectors would be the best for this and for the money.
Old 07-04-2007 | 12:41 PM
clutch1's Avatar
are you on the stock turbo? if you need injectors i would go with the cleanest ones you can find and for towing don't go to big. maybe try the DDPs like theyre stage 2s you can try new eras for a little less money also. i wouldnt go with the marine 370's. also have you already maxed out your pump with adjustments like your housing, aneroid, plate position, i assume you have guages.
Old 07-04-2007 | 01:32 PM
one54ton's Avatar
New Eras are nice and so are DDPs. Go small on a stock charger or your egts will become leathal.
Old 07-04-2007 | 01:34 PM
RSwood's Avatar
Yes I have guages EGT, and boost with trans coming soon. also the trans has been upgraded. I'm kinda new to this so I don't know what you mean by maxing out your pump with adjustments like the housing and aneroid. As for the plate it was installed before I got the truck so I'm not sure on position. I would be intrasted to know which is better forword or back. Also the turbo has a banks big head housing outherwise stock. THANKS
Old 07-04-2007 | 04:07 PM
clutch1's Avatar
the more forward the plate the more rack travel. move the housing all the way forward, housing that you take off to access the plate. for towing purposes dont mess with the starwheel, start there and see what you got. how does your truck run as it is now,what kind of low end, smoke, and top end?
Old 07-04-2007 | 07:49 PM
RSwood's Avatar
I consider the low end smoke to be minimal and the high end to be almost nonexistent and that's if you floor it. I also have a T/C lockup switch that I turn on at about 30 or 35mph but it only smokes under heavy throttle outherwise vary little smoke towing or not. power is good but I would like to have a little more for heavy towing or something else. Outherwise the truck runs good. THANKS
Bradleysram
19
05-12-2009 09:36 AM
KRB
05-20-2007 07:20 PM
BIGOKIE
07-21-2004 06:53 PM
mcevins
12-02-2003 12:38 PM
atc250r
05-12-2003 03:56 PM
