Injectors?
Old 06-17-2007 | 04:28 PM
cj7usmc's Avatar
Injectors?
i have a 2000 Ram 2500 with an Edge Juice Module. THe engine is misfiring at around 1500 rpms, usually about 30-40 mph. i changed the fuel filter 2 days ago, it idles perfectly and all levels of the juice work the way they should. it does the same thing if i set the module to stock. it will kick for a few strokes and then resume firing. there is no lack of power after or before that, just 1400-1700 rpm. any ideas?
Old 06-17-2007 | 09:20 PM
iforge03's Avatar
maybe check fuel pressure. are you running the factory lift pump?
Old 06-17-2007 | 09:25 PM
cj7usmc's Avatar
fuel pressure is good, checked it twice and the module reads it at a constant 18-20 psi. yes, the lift pump is stock.
Old 06-17-2007 | 09:49 PM
displacedtexan's Avatar
Are you checking it under load?
Old 06-17-2007 | 09:52 PM
cj7usmc's Avatar
yeah, my buddy is a diesel mech and he thinks an injector might be bad, but the question is which one injects the fuel at that specific rpm and how do i know its bad. so i dont know, but i dont wanna let it go too much longer.
Old 06-18-2007 | 03:10 AM
HOHN's Avatar
Injector failures on these trucks are pretty rare. HPCR trucks, yes-- but not early 24Vs.
Far more likely that it's the injection pump. See if you can get this pump tested before just throwing parts at it.
KRB
05-20-2007 07:20 PM
GSP
12-11-2005 01:20 PM
W.F.O.
11-03-2005 11:33 AM
darrenG
06-21-2005 11:24 PM
BIGOKIE
07-21-2004 06:53 PM
