Which injectors??
With the setup that I have right now my Pyro maxes at 1100 on the 5 power setting at WOT. My truck has about 6000 lbs on the bed all the time. HTT Turbos told me that the HTB2 62/14 turbo would handle 150's just fine, but from what I gather not all 150's are the same. I do not drive at WOT that much, but of course who can resist stomping on it every once and a while.
heres the pm quote from elandon1201:
I have the 14cm Housing I can hit 1500 degrees still but not nearly as easily as I could before with dd2's and stock charger. I would suggest MACH4's before MACH5's though, I am thinking about stepping back to 4's.
2001 2500 Sport QC LB 4X4 - ATS STAGE 5,MACH 5's,SPS62, II HRVP44,HOT JUICE WITH ATTITUDE,FASS,FS-2500,5" EXHAUST,AFE STAGE 2
7/22/06 Dyno 564HP 1095TQ on #2
614HP 1200TQ with a little shot
this is elandon1201 truck , i hope he dosent mind.
this should help with your decision, you should be fine considering hes running the HOT JUICE.
good luck, brian.
Thanks for the advise. I'm going to try the M4's, I think I'll replace my stock lp with the FASS before I do this though. What do you guys think?
edit: nevermind i forgot about the miller in the back.
good luck, brian.
Before I commited to buying the F-1's, I would take a look at DDP injectors. IMHO they are the best available. They haven't been around as long as the F-1's, so they don't have as many people using them. In fact, I'm really surprised that no one else has suggested them. I have Stage 5's and they are awesome, very smooth idle (they are all balanced so they flow the exact same lpm), low smoke and they make the power! Take a look here, www.dynomitediesel.com, you will not be disappointed.
Good Luck!
Has anyone else used these injectors?
The #'s in my sig were posted with these injectors and a Comp. No Smarty or Fass. On injectors only (no electronics) I ran 410 HP, I can't recall the torque. The really cool part was almost no smoke. Guy's that were there couldn't believe how clean it was. DDP's run smoother, you can hear the difference!
Bradleysram
19
05-12-2009 08:36 AM
