injectors
injectors
What are the best injectors or tips for the money. Where can I get them. I dont want to make a hot rod truck, but up the power a little and still have fair fuel mileage. I have a edge comp now.
Iv got RV275's about 50 hp and work great with my edge juice, fuel mileage went up about 1-2 mpg. look around and you can get a set of used one s cheap from somebody who is upgrading to bigger ones. They are a great mild upgrade for what you want.
The Mach series injector from Formula 1 are by far the best in my opinion!! There website is www.f1diesel.com
~Nick
~Nick
Registered
You will get a good boost of power from what ever you get, some just smoke more than others, and some are a little over rated, HP wise, but if they say 150 and you only get 125 you won't know the differents. I've run the jammers 4 and I now have mach 6's. They both got the job done, the jammers smoke more, but were alot less $
I did the same. I didn't want to smoke the stock tranny. Got 275s and an Edge EZ--no problems in the drivetrain.
For all around use, I like the DD Jammer 2s. I have a set of Jammer 5's ready to drop in, but have never tried them. Next spring, I plan to try them back to back against my Mach 4s (also 150 hp). Anything bigger is just too hard on the engine for daily use in my opinion. My big injectors smoke at idle and soot up the oil very quick.
im running the bosch 370's in mine. me and the truck love them. not sure how much more hp they make, but its a kick in the pants. price was real good too. the only thing that some dont like is that they make insane smoke (as in shut down intersections), me personally, i love it. the 370's work well with all the other things i have done. if you dont have alot of other thing upgraded, you may want to go with a more mild set.
floridadieselki, i seen in your sig you have a banks intercooler i didn't think they made one for a 12v, if not how much work was it to make it work? also u have a holly aux. pump hows that working for you, is it much of a difference on a 12v?
darrenG
06-21-2005 10:24 PM
