Injectors
Sure. Could run it forever but need to keep your boost no higher than 32 psi. Above that your over reving the turbo and pumping super heated air and loosing HP. Can run it....just can't use all your throttle!
You asking about Mach 4's with no box? The 62/12 would be great. With a box I would want a 64/13.
RJ
RJ
Another angle..
What would be better, a set of RV275's / Edge Comp combo (with HX35/12 - I like the quick spool).
Or Mach 4's only (with boost fooler module - no other electronics - stock ecm) and the same turbo.
I like the idea of getting rid of electronics and going with injectors only, just dont want to lose MPGs, & raise EGT's.
Any thoughts on what the differences in performance would be? Thanks
darrenG
06-21-2005 10:24 PM
