Injector replacement questions??
Hi, I am looking at replacing the injectors in my 2001.5 HO/6 speed 4x4. I currently have a Banks Power Pack in it which included a bigger turbo housing, ram air manifold, gauges, 4" exhaust and ottomind computer. The truck makes 36 lbs of boost. I bought the truck like this and so far so good, but i want a little more power and smoke when i want to. i have seen the Bosch 275's for cheap, and was also looking at the DD 2's. Form what I have read the DD's will give more power, but cost a little more. Right now my truck will barely smoke, it's almost invisible. What kind of smoke can I expect with either of these injectors. Any suggestions welcome, thanks, --Neil
With the Banks Ottomind computer it will defuel to contol egt's so i dont think you will get it to smoke much with any injectors.Now put on a comp box or a tst & you will get smoke & high egt's.
Kurt
Kurt
The DD2's will make twice the power (roughly 90) than the 275's, and you'll get the smoke you want.
But save some $$ for a clutch too because you'll be past the limits of your stock one.
Startup smoke
My 275's will smoke on low boost because I have the TTPM on level 2 which only fuels after the boost has reached 12 psi. Of course, the ECM doesn't know about any of this, hence the smoke. The combo I have is about all the stock clutch will handle so if you get the DD2's, you'll need a clutch upgrade.
Jim
Jim
Sleigher
05-18-2005 01:22 PM
moparsupremist
04-20-2005 11:33 PM
