Injector Rebuilders/Modifiers
Is there a good place to send my injectors to, to have them checked/modified?
They are supposed to be performance injectors but I have no way to verify that so I wondered if there was an injector service that could look at them and tell and maybe tweek on them if needed.
Your sig says you have POD's, POD's are a 4 hole tip, pretty big holes too, you should be able to see them very easily. They are also not a bosch nozzle holder, they are a Lucas/Delphi injector. The injector body will look slightly different from the stock holders.
The only thing a shop can do is check the pop off pressures and adjust them if necessary.
Sorry Fellas This engine Is not the 93. Its a 97 that I am going through. Thats why Im in the second gen forum but of course since I didnt say 97 you would think different by my sig. Sorry about that.
Anyway you asked about Smoke with the POD's It smokes http://www.youtube.com/watch?v=SW6731cuZ3o pretty good and the HTT Stage IV clears it up fairly well
Lucas POD has a special meaning for me since driving a newly restaurated Jaguar E-type at about 3 am with a speed in excess of 110 mph and switching to high beams... helooo it's dark..... back to low beams.. still dark..... Pure luck that I got it to stop without hitting anything.
About the injectors- you could contact DonM from F1Diesel.
AlpineRAM
AlpineRAM
belfert
12-05-2003 01:57 PM
