Injector Pump Replacement Advice
Ok, I posted last week and found out that many people claim to get more HP from a standard output pump, than a high output. With that being said, check out the few mods I have on my truck, and someone let me know what the BEST choice from ALL available Injector Pumps out there would be. I don't care to spend a bit more to get a better pump. Mods are as follows:
FASS Fuel System
80hp Injectors
100hp Power Edge Box
Considering I have the bigger injectors and a fass fuel system, would it be best to go with something bigger than a standard or high output? Please, as many opinions as possible.
By the way, this is an 01 Dodge, 24valve Cummins
FASS Fuel System
80hp Injectors
i would just go with the SO pump. you can make just as much power with that pump as you could with the HRVP. the only reason i would purchase the HRVP is if i had a stock truck and didnt plan on adding any other mods.
brianblack138
02-22-2009 03:21 AM
dodgemaniac
Competition / Pulls / OffRoad
07-31-2008 10:15 AM
TJ0993
11-08-2007 10:27 AM
moparsupremist
04-20-2005 11:33 PM
