injector pump? please help
my dad's truck is an '02 5 spd,stock other than Carter lift pump, 4" straight pipe, and bd low fuel pressure light
it has no power on take off and white smokes excessively, but once driven for 8-10 minutes it has good power and white smoke clears up, also the low fuel pressure light has not come on yet
many thanks again
Smoky Beast
many thanks again
Smoky Beast
0216: injection pump timing error.
P0234: i think this is overboost code
P1693: just a code telling you there are other codes.
That 0216 is frequently present when your VP44 dies. Not always, though. Other things occasionally cause the 0216 code, but it's associated with a bad injection pump.
jmo
jmo
Yes 0234 is overboost. Disconnect your negative lines from the batteries and turn the key to the on position for a half hour or so to clear the codes. Watch to see if the codes come back and start saving for an IP
TJ0993
11-08-2007 11:27 AM
moparsupremist
04-21-2005 12:33 AM
