View Poll Results: Which is the best option?
Fix pump governor for $400, still have 291K mile pump
31.25%
Buy stock replacement for $1000, lose 215HP pump to core
18.75%
Buy Jannetty Racing pump for $1900, keep 215HP pump for whatever
37.50%
Other?
12.50%
Voters: 16. You may not vote on this poll
Injector pump fix/replacement options, which do you suggest?
#31
Yeah when I first start the truck, I have to give it fuel to start and stay running, but once running it's good. Only other problems is when taking off, I have to give it fuel, and when coming to a stop, when I let off the fuel and push in the clutch, RPM's start dropping, sometimes they drop to about 200-300 and rise back up, and sometimes they just keep falling to 0 and the truck stalls out. Driving around it seems fine though.
To tell you the truth, two simptoms of yours sound like tight springs,
and one sounds like loose springs.
when pressing the clutch and the rpms drop, and come back up, & truck dying, had that experience with our truck, BUT it has a 4k GSK in it, so i tightened the springs two clicks and twas good to go! no more probl.
but when taking off, and it has no power, and you have to give it fuel on start up, (both i hate) i found that loosening the springs 2 clicks and adj idle acordingly helps!
but also, ive found various friend's pumps with mayor gov problems, after dropping something in there! (broken pump side walls, broken pin's, no more rpm regulating, etc etc)
i really dont know, find out tuning with your springs, if it doesnt help, then try finding more expensive alternatives....
ive worked with so many gov springs, i need no vernier caliphers no more! it aint all that important! i can see how they must be, / work best!
but i cant see from 12 hrs away from ya, what your pump's probl is....
where does your truck cut out rpm's on empty rev up? (neutral)
#32
Yeah see that's what so weird, it looks like the springs could go either way!
My truck DOESN'T cut out. . It goes up to 3500 before I let my foot off. I guess I got a free 4K GSK by the bolt dropping down there.
#33
UPDATE: Truck still runs the same way, been driving it like this the whole time. I'm at the point where I want to beat my face against my trailer hitch every time I have to drive this thing it runs so horribly. I think part of it is now the needle valve for the gauge is leaking, and the bar going through the valve to turn it fell out, so I put a cotter pin in there to try and turn and they bent. Beats me.
Either way, I'm going to buy a new pump now. Got the OK from the wife to just buy a new darn pump already.
dahla
36
02-11-2011 05:17 PM
palehorse
06-17-2009 05:04 AM
Z06-LITE
01-23-2008 02:22 PM
bob95065
08-25-2007 09:04 AM
j28s
10-07-2004 09:52 PM
