Injector Nozzles install Q? /Advice/
I have some nozzles headed my way, anyone ever installed nozzles?
Also has anyone ever installed a FASS "pump" with the special pick up straw?
Thanx in advance
The vp44 swap was nothing.
01 CTD 6spd
Thanx in advance
01 CTD 6spd
i can swap a set of nozzles out in less than an hour. very simple swap. and i mean very simple. pull the valve cover, pull the flow tubes, pull the injector and replace the tip, and put it all back together.
Come on, less than an hour for the whole job? If so, you're the man...
OK got the FASS 150 pump on there and the vulcan pick up straw.
Getting 21lbs at idle now, tomorrow ill replumb the vp44 and put the nozzles in.
Hopefully the truck will lift the left front tire off the line now.
1985cucv
05-09-2010 10:15 AM
dodge_24
08-30-2009 09:50 PM
dodgemaniac
Competition / Pulls / OffRoad
07-31-2008 11:15 AM
HOdiesel80
01-31-2007 11:46 AM
Amish hauler
02-22-2004 10:42 PM
