Injector Lope??
Injector Lope??
I installed edge jammer tips awhile back, instead of putting them on my RV275's which hav less miles on them, I put them on my stock injectors I had lying around to make the process quicker. Now it has quite a bit of lope to it and sometimes seems to be worse than other. Is this normal, or do I have a problem? Should I have put them on the RV's instead. And anothe in a hurry problem I did not have them pop tested....The lope sounds really cool, but then again is it normal or a bad thing.....thanks Joe.
Recheck all your injector lines to make sure they're not tight. Is the fuel tank pressurized? Maybe a loose injector hold down, any fuel in the oil? Bad washer, oring or crossover tube.
Just some things i have found when this condition is present.
Satan's Chariot
07-11-2006 02:50 PM
SoTexRattler
03-14-2005 10:28 AM
