Injector Advice Requested
Check my signature block for current truck status. I'm looking at the next bomb as injectors. Early, I thought RV 275's were the way to go but lately, I've been told that DDII's would be a better choice. THEN, I've received information that going to DDII's would kick my EGT's up to a higher level (he suggested 1300's). Considering that I don't tow or haul and use my truck as a daily driver up and down the super slab, would I see these higher EGT's? Am I missing something here? I have planned on adding a Scotty II, with 4 1/2 " hole modification sometime prior to towing. This is indeed a slippery slope once you start bombing.
~Dave
~Dave
Location: Drive till ya hit a Polar Bear, then go back 50 miles
Re:Injector Advice Requested
Hey Dave!<br><br>Since you're not towing, you probably won't see the 1300F range, unless you're at wide open throttle and climbing a good hill. And I wouldn't worry too much about 1300F either. These engines will take that without a whimper.<br><br>Rod
Thank you Gentlemen. Advice received and appreciated. Oh what a slippery slope we slide on when first we decide to BOMB.<br><br>~Dave
SFCHubie
10-20-2011 10:43 PM
PapaPerk
10-21-2010 02:10 PM
betsycam
08-01-2006 04:44 PM
redramnc
08-06-2003 07:30 PM
