injector ?
injector ?
I am looking at getting some Jammer III nozzles. I have heard that you need to have your injectors tested after installing the new nozzles. Could someone give me the correct termiology to use when I contact my local diesel shop (Oregon Fuel Injection). I don't know what tests need to be done.
Also I plan on adding a Van Aaken around the same time and need to know if this set up will work for towing and not be too hot.
Thanks,
CJ
Thanks,
CJ
City Diesel, www.citydiesel.net, sells complete Jammer injectors already tested for around $300-$400. I have never dealt with them, and also have never had it explained to me how they can sell them for that price when everyone else seems to want over twice as much. There may be some difference in them but it isn't apparent.
Edge Jammer Injectors 03
I have a Dodge 03 SO Auto 4x4 HD, w/Edge EZ set on level #3, new torque tube, 4 in. Flo-Thro muffler. If I install stage 2 Edge jammers, is this a good combo? I pull a 5 th wheel camper, and a GN 20x8 ft dump trailer. Don't want a race machine! Thanks. javahjoeo from Kokomo.
Well I have the J III nozzles and an EZ. IM seeing about 33-35#'s of boost and my EGTs have not gotten above 1200*. I have not towed anything and have not made a WOT run past 75mph. The install was fairly easy, Do your research on here. I did not have mine pop tested, and I think the result is a little rougher idle. Every 4-5 seconds it will lope. Once I get the RPM's up to 1000 then everything is smooth as silk. It is a great combo for me, I didnt want to change the stock clutch(dont know how it will hold towing) and I didnt want to change the stock turbo. I have found out the the right foot controls EGT's and how the clutch gets treated so I figured to skip the rv275's and make a little bit of a jump. Very happy with the results.
Jamie
Jamie
Registered
you really dont need them pop tested. ive installed two sets of jammer nozzles and havent pop tested either set and they work great. if you test them they will perform a little bit better but theres going to be so big of an increase anyways you wont know the difference. pop testing is a waste of time and money. they tolled me that more than 90% of jammers installed are not tested IMO
Originally Posted by micah
how much does this pop testing usually cost?
It depends where you go and if you have the injectors out of the truck. If you take just the injectors in, some shops will do it for free. Most of the shops around here charge from $5 to $10 per injector.
Originally Posted by blackdiesel02
you really dont need them pop tested. ive installed to sets of jammer nozzles and havent pop tested either set and they work great. if you test them they will perform a little bit better but theres going to be so big of an increase anyways you wont know the difference. pop testing is a waste of time and money IMO
The whole point behind pop testing the injectors is to balance the set to inject fuel at the same point for each cylinder. If one cylinder is lower than the other, it effectively changes the timing for that one cylinder.
When you are installing nozzles into used bodies, the springs can have a different amount of pressure, which may require different shims. Maybe some people get lucky and they go right in without having to be set differently, and maybe some don't. If you're spending money on the truck, just make sure you do the job right.
Registered
Originally Posted by KLockliear
That is extremely bad advice. Gotta love the internet for all kinds of information I suppose.
Never said it will damage the engine, but then again, we don't test the opposite of the right way just to see what we can damage.
Inconsistent, low or high pop pressures can cause the following: it may run rough, idle inconsistently, make more noise at idle and make less power than it could.
