injection pump question
if my pump is going out would it be worth getting one under warranty by removing my injectors and my box. or should i get an after market pump? I am planning on doing lots more to the motor when i get the money.
thanks in advance for your help.
The Guru
Just pull off the box. Forget about the injectors. The only way to determine if your running larger injectors is to do a flow test. Most dealership wont put that kind of time into investigating the problem. I haven't had a issue with my warranty, but that was prior to my twins.
tommurray
02-23-2014 10:38 AM
billygoat02
12-29-2005 11:03 PM
Yukon Dodge
18
07-01-2004 10:08 AM
