Injecters
Injecters
Hey all, Ineed advice as to which injecters to by ,dd or mach, and what size , hary at pdr recamended dd3jammers has anyone got dd jammers how do u like them how do they compare with machs I also have a pmax3 on my truck thanx all
Mach injectors. The best injectors at any price-- period. They just happen to be reasonably priced.
How big depends on what you're doing with your truck. Towing, go with the small 85hp injectors (mach 1.5).
If you're mostly just looking for hp, then try some mach 2s.
If you're going to be upgrading the turbo, then you can go pretty big-- mach 3 or 3.5.
Justin
Justin
I second HOHN- I'm running Mach3s. You will have to take care of your clutch though, and depending on usage of the truck and injector size you'll have to go for more turbo than you have now to keep the EGTs in check. (I hope that you have gauges).
AlpineRAM
AlpineRAM
dsl-nut
Both are EMD's
You need to decide where you want to end up, power-wise, before others can make suggestions. Had my Mach 2's tested before installing and they were matched perfectly. Don't know about quality control on the Jammers?
If your going to have bigger injectors and your PM3, plan on future spending for a clutch and maybe a bigger turbo, unless you want to have to control EGT's with your foot a lot of the time.
RJ
RJ
rjohnson- DonM's Mach injectors are EDM's (At least he sells them as EDMs)
http://f1diesel.com/page1.html is the homepage.
I don't have any experience with dd's jammers, just the older ones.
Let's say that I am very content with my injectors and they had no ncrease in low boost smoke, no decrease in mileage and no observable wear for the last 130 000 kms. So I think I can recommend them.
AlpineRAM
AlpineRAM
Machs? Extrude Honed? Surely you jest! Don does offer honed injectors, but not for sale to the general public. You have to call him and request them.
If you order F1 diesel from www.powerbypoole.com or www.sourceautomotive.biz or www.wildcatdiesel.com they are without a doubt EDM injectors.
In addition, there's a lot more to making an injector than whether or not it's EDM. Number of holes, spray angles, pop-off pressure, rate-of-discharge, on and on and on.
While I have no personal experience with the Jammers (other than hearing rumors of how they based on someone else's work), I HAVE seen the incredible performance, mpg, and torque of the Mach injectors, and I would put them against anyone's injector. For a given HP, I'd be so bold as to say no other injector makes less smoke and more torque, or gives better mileage.
Again, I have no experience with the Jammers. I have seen no reason to even try them.
Justin
Justin
AR & JH
I should never start typing till after first cup of coffee!!
I edited my previous statement about the same time you were both politely telling me I didn't know what I was saying. Thanks.
RJ
RJ
I am going to get a southbend clutch and may a turbo upgrade down the road , hary advised jammers3 ,and i found a set for 639 but if the machs are better ,then I dont mind spending more $$$$ what stage should I go with? I also would like a little smoke between shifts
Mach 3's will give you a little more smoke and 25 hp more and still be very streetable.
See http://mysite.verizon.net/res06gkt/page1.html
I think prices listed there have come down a little but not sure.
RJ
RJ
dsl-nut,
The Mach 2's will make the same power as the Jammer 3's in all cases. Mach 2's generally give 450 rear wheel horsepower or more with an HX40 or a B-1 and a comp box.
If the turbo is stock....I suggest a Mach 1.5. The newest nozzle for the Mach 1.5 we began using this past month will come within 5 HP of a Jammer 3. They produce less smoke, more TQ and a smoother idle as well.
Don~
Don~
