Improving Fuel Mileage
I recently bought a 99 Dodge 3/4 ton with a 24V Cummins. This truck has 140K miles and seems to be in great condition. To my knowledge it doesn't have any modifications at all, straight stock. With fuel prices continuing to climb higher and higher, is there any suggestions to improve my fuel mileage? I have been getting 15-16 mpg consistently for the last 6 months.
One other issue I would like to ask about. The last few weeks the transmission has been acting up. At speeds between 40-50 mph, it is shifting in and out of overdrive. I have been told that this is the "lock up" feature of the transmission.
Any help on these two questions would be greatly appreciated.
New to this site, and also new to driving a diesel, but loving it so far........
The average life expectancy of the factory auto transmission is 150K. I had 158K when I swapped mine, but I did not have any problems with it at all. The in and out between 40-50 sounds normal. Only two things to do; 1) Don't drive in that range. 2) Lockout OD and stay in 3rd lockup.
RJ
Originally posted by HOHN
Mach 1.6s and an EZ.
Open exhaust and hi flow intake.
After that, it's all tire style/size/pressure and driving technique.
jlh
jlh
Intake = $240.00
Exhaust = $400.00 plus install
Edge EZ = $450.00
Total = $1790.00
So,
Diesel is at $2.20 (just an average) You get 16 mpg You also travel 1,000 miles a month (example again)
Your operating cost would be $137.50 a month.
Lets say the above mods net you a gain of 2 mpg better making it a total 18 mpg.
1000 miles /18 mpg = 55.56 gallons * $2.20 a gallon = $122.23 dollars a month that is a savings of $15.29 a month!!
You would have to drive a total of 117 months to pay for your mods.
Or, you would have to drive a total of 117,163 miles to start getting any benifit.
My wife did this to me and it humbled me right up!!!
Don't forget you got all the parts installed for free and got free gauges. (You need those too)
A good rule of thumb is do the mods because its COOL, and it makes more POWER!!
Justin
Muted User
Justin come on buddy... the guys from texas. Its gunna be something similar to this
BHAF = $40
Muffler cut out and pipe welding in = $30
Edge EZ from the "whoresellers" on ebay = $400
Silencer Ring removed for effect = Priceless
Paying for itself in 2.5 years
Ok i'm just messing around but just throw an ez on it and your good to go. You do intake exhaust injectors all the goods and you are never gunna be able to keep your foot out of it.
BHAF = $40
BHAF = $40
BHAF = $40
Silencer ring for affect!! You are killing me.
You are dead on about not being able to keep your foot out of it.
With a BHAF/straight pipe/silencer ring gone they sound like "recently violated ape" screaming down the road. There is nothing better then rolling the passenger window down and hearing the sweet cummins roar!!
Justin
Originally posted by Dennis
But it sure helps justify the cost knowing you're gonna save a little at the pump. " But honey, these fuel prices are killing us. These mods will actually give us better mileage"
O ya, Welcome luf02145.
As for mods to get better mileage... I would run a comp in EZ mode. You can tap the wire once the bug has gotten the best of you, and then add a set of RV 275's. That will net you atleast 2-3 miles per gallon better.
You will have a blast with just a comp and RV's.
Justin
codered
13
08-15-2008 02:35 PM
MtnTrucker
10-23-2007 09:35 AM
pwabbott
23
12-19-2002 09:51 PM
