If Ya Got A Tranny Temp Guage, Please Assist Me.
Old 09-18-2006 | 11:06 PM
J BODY's Avatar
...and if you can with the "brass T" styles shown. Try to get the probe opened up and as close to the fluid flow as possible. Some times when using the T and adapters the probe ends up shrouded and will not react as well. Learned that on my 95.
Old 09-19-2006 | 07:10 AM
Ridiculous's Avatar
Originally Posted by scottsjeeprolet
I did the same thing as RattlinRam did . got the fittings form McMaster Carr.
Here is the part #Mcmaster carr part # 5929K146 1/2"x3/8"x1/2"
i like this idea, but, can you please explain to me things like, where is it located (on the truck, like where do you put it i mean), what is it threading on to, i don't get that part, and anything else that seems necessary....
Old 09-19-2006 | 07:38 AM
Shovelhead's Avatar
Administrator / Scooter Bum
You remove and cut the hard line going from the transmission to the heat exchanger.
The "T" uses compression fittings to seal to the ends on the cut line.
Old 09-19-2006 | 11:03 AM
whiteVLX's Avatar
Originally Posted by dieselfan
i have mine in the test port #2 and if i sit somewhere the temp will go up 20-30 degrees quick, with in 5 minutes. if i race around i can get it up to 180-190 degrees. is this accurate?
Mine never acted that quickly. Here's a link from DTT where Bill explains why not to use the temp sender in the test port.
http://www.dieseltrans.com/phpBB/viewtopic.php?t=558
Old 09-19-2006 | 12:30 PM
red_rattler's Avatar
Check RattlinRam's gallery to see his setup.
Low-Buck, parts available at most any auto parts store, and has survived for many, many miles.
....Found the picture:
That's what i did with mine and it's been like that for 110,000 miles with no leaks. It is the easiest to do, no drilling holes or welding nuts on. You will have to cut the correct line.
Old 09-19-2006 | 12:42 PM
Gotlift01's Avatar
Maybe this was answered all ready, but where do you get that T-fitting?
~Nick
Old 09-19-2006 | 12:47 PM
scottsjeeprolet's Avatar
Read up above, or http://www.mcmaster.com/
Old 09-19-2006 | 12:52 PM
Gotlift01's Avatar
Ahhh thanks for the link.....I saw the mcmaster part but wasn't sure if that was a website or not!!! Cool......thank ya kind sir!!!
~Nick
Old 09-19-2006 | 01:06 PM
Gotlift01's Avatar
So which line do you splice that into?? Just wanna make sure I cut the right one!!!
~Nick
Old 09-19-2006 | 01:08 PM
zukgod1's Avatar
That right there is great info.
I had mine in the test port most of it's life. I wasnt to concerned about the temp being way off as I never pulled anything (kinda like a post EGT probe) so I guess it was more of a toy that anything, I was however concerned about the sender making contact with the spring or servo. Now I know my concerns were valid.
Thanks for the post.
dan
Old 09-19-2006 | 04:05 PM
Txwelder's Avatar
I believe the line is the upper most forward line on the passenger side of the tranny. After driving get under and feel them both. One is a hot line to the cooler and the other is the return. Note the hot one and come back after it is cool and cut it. Just make sure you put all your fitting together first so you can know how long the assembly will be and not cut too much line off. You can always cut more but you can never add on. You will have to find a spot where the assembly will fit in the line, mine is not vertical like in the pics shown. Mine is horizontal right at the back section of the block. I got my fittings from Napa, dont remember the part numbers but they are on here in a thread someplace. Has lasted at least 20K for me and no worries. My temp sender wire is zip tied to the tranny filler tube as to keep it off the downpipe. Good luck.
Old 09-19-2006 | 06:09 PM
Gotlift01's Avatar
Awesome thanks!!! I have my sensor in the pressure port and I knew it wasn't that accurate, so I want to do it this way so that I can make sure I know exactly how hot is getting!!
Thanks again for the input!!!
~Nick
Old 09-19-2006 | 06:38 PM
I PASS GAS's Avatar
As far as that T that everyone is mentioning @ McMaster-Carr...would that be type compression T that one could pick up at HD/Lowes?
Old 09-19-2006 | 06:41 PM
Gotlift01's Avatar
Yeah it's a compression fitting on them.......should be able to pick one up there.
~Nick
Old 09-21-2006 | 12:03 AM
ProspectorTim's Avatar
The BEST way (in my opinion) is the '95 (I think) "Hot" side transmission line that had a fitting for a temp sensor already incorporated. Part number 5011244-AA
The line is ~$100 from the dealer or from an aftermarket source.
That's the way mine is installed.
OK, now I'm confused. Shop.com shows p/n 5011244AA is for 94-98 Ram and looks like STOCK line. $34.95 +s/h sure sounds like a good deal though!
Is that really any better than putting a T fitting in my existing line?
