If I get sticks, will I need a turbo?
I don't know what the deal is on mine... previous owner had some injectors go bad and replaced the set, but don't know what with. They smoke like crazy and if I drop from 5th to 4th, my EGTs fly above 1300 pretty fast. If these are stock replacements like he thought, I'd go with at least a hybrid turbo. Lord knows I need one.
You will be fine if you advance your timing, as said lots of people run 370's on the stocker and DDP3's should be IMO a cleaner, cooler injector. I am running some BIG sticks in mine with the stocker still and daily driving is very controllable and for towing all you need is a valet switch A GSK isn't hard to install it is just time consuming...
http://piersdiesel.com/TechGSK12V.htm
I used that as my guide and all went well! Infact I am going to be putting in my 4GSK as soon as it gets here
If you put those DDP3's, 3GSK and bump your timing to 16*-17* you will have a whole new truck!
ull need a charger tho, even with the smaller injectors, just to keep things cooler, if ur not much into hot roddin, the truck will be much sweeter respondin 0-60, Just talkin out of experience with 370s and a stock charger...
Rick
Ok my bad those would be DDP2's... haha that would be a good combo IMO with the stock charger. An upgrade would be good turbo-wise but not 100% necassary. You could adjust your plate, AFC, and starwheel position to control your EGT's. Do you tow? If you don't tow put some ARP's in there and bump the timing to 17*-19*, it will have a little less bottem-end but rip and roar up top. My EGT's top out at 1550* at 97MPH in 4th gear with my BIG injectors, plate 2/3 way forward and AFC setup.
Turbo would be a good idea.. I have switched to a slightly bigger S300 and still have EGT issues. Addin sticks would be even more of a problem for me.
6.6lEater
09-26-2010 01:24 PM
TNRIPNROR
04-17-2009 01:10 AM
jgiachino
05-12-2008 02:06 AM
jrussell
09-26-2007 07:25 PM
