if i buy a smarty
Muted User
if i buy a smarty
stack it with my drag comp...
will it make more power by adding more fuel
i mean how much can go thru the fuel sel if ive got the comp maxed and the smarty maxed.
all i really wanna do is eliminate the torq gard
will it give me more power or just change the curve
I've done alot of testing on the street and dyno with a smarty and dosent seem to stack well with the Edge comp, but has great drivability for large chargers
Your egts will go up and your turbo will spool up faster and it will smoke like crazy. My buddy running 525hp @ the wheels, lost 70hp but it did spool up faster. Hope this helps.
Smarty has cost power when stacked with a drag comp on several trucks including Timinva's. 70 hp is a lot though- I'd want to see that graph too. I'm guessing it was different dyno's?
Best combo ive seen with my truck is the TST/EDGE dragcomp in Ez mode, over the TST/Smarty, and Drag Comp Alone,even though the TST/Smarty is funer on the street cause of the drivability, so ive done alot of testing and tried them all, only thing left i need to try is if the TST/Smarty will make more that the TST/Edge comp ez mode with Nitrous.Should be with in the next week
Not as much as i was expecting but it made around 550 on fuel, 7's are just too much fuel for a single 66 charger, i'd probably make more with just 6's but they have enough fuel to make that with spray
stock03
34
04-21-2011 07:40 AM
Badd Dogg Guy19
14
04-14-2005 09:04 PM
