Idle rpms
Old 01-27-2005 | 07:03 PM
mitch@jc'sCTD's Avatar
Idle rpms
How many rpms should my truck be at when at idle? I heard 750 but it is only like 500. How can you increase the rpms at idle? Will it mess up shift points and the engine overall?
Old 01-27-2005 | 07:14 PM
infidel's Avatar
750 in drive with the A/C on
Click here for instructions> http://dodgeram.org/tech/dsl/adjustm...d_Gen-Idle.htm
You'll have more problems with the idle too low than you will with them correct.
Old 01-28-2005 | 04:15 PM
Anyone else have an opinion?
Old 01-28-2005 | 04:47 PM
got...DIESEL?'s Avatar
mine was low....750 in park, no loads. 500 loaded in gear. I raised mine to 750 in gear with all loads on.....lights, AC, and fans. Idle is easy to raise, and will not affect any other variables.
Old 01-28-2005 | 05:41 PM
CTD NUT's Avatar
Infidel steered you right........it's not too hard to adjust once you locate the screw.......you can't see it - you have to feel for it........The dodgeram.org directions are great........it is a good site for technical service data and pics.
Old 01-28-2005 | 07:16 PM
dansdodgediesel's Avatar
What are the 24v supposed to idle at?
Old 01-28-2005 | 10:09 PM
JKM's Avatar
JKM
The idle is not hard to adjust at all , and once you find the screw you can see it too , stand beside the truck , and look right down over top of the master cylinder , it is very easy to adjust , especially if you have a 10 mm box end racheting wrench , one with a swivel on the end , it is a snap to adjust. did it on mine a few weeks ago,
Old 01-29-2005 | 01:29 AM
infidel's Avatar
Can you even adjust the idle without a scan tool?
Old 01-29-2005 | 01:34 AM
heavyboostin's Avatar
mine is at about 850 or so i would say in nuetral or park, and right above 750 when in drive and with brakes applied,
Old 01-29-2005 | 07:33 AM
I don't think you can adjust Idle in 24v. Mine Idles at 875 or so. Think it's kinda hi.
Old 01-29-2005 | 11:19 AM
turbo thom's Avatar
Infidel is right. 750 for the auto and 900 on the 5 speeds. Still I set mine at 850. I just don't like the higher rpm.
..Preston..
Old 01-29-2005 | 10:17 PM
So is 750 in park ok or should i adjust it to be 750 in drive with the brakes on?
Old 01-29-2005 | 10:42 PM
DustyRock's Avatar
Listen to Infidel. He will not steer you wrong.
"750 in drive with the A/C on
Click here for instructions> http://dodgeram.org/tech/dsl/adjust...nd_Gen-Idle.htm
You'll have more problems with the idle too low than you will with them correct."
1994-1998 with AT - in drive with AC on 750 -800 RPM
65fury
07-26-2008 12:47 PM
fbx22
04-18-2007 11:50 PM
SHAKEDOWN
06-14-2003 03:39 PM
iwannaram
24
12-21-2002 12:56 AM
Quick Reply: Idle rpms
