Ideal stroke for B5.9?
DTR Advertiser
The stock cranks in the Dodge/Cummins are Forged Steel. A huge percentage are all Forged Steel. I think a few may have had a cast crank in very low power density engines. The cheapo China stuff I see vendors dealing are all cast, but not a bad part for the money if the HP levels you want is not real high. They use the Vickers system to test their products so expect a low Rockwell test number. A number low enough to fail the Rockwell test by Cummins spec, but once you convert Vickers to Rockwell..its considered OK by many.
The fillets radius used on the flange is best left the way Cummins did it. Good design/spec.
They are fully fillet hardened. Grinding is hard to do correctly without burning the fillets on the grinder. This extends into the journal area and should never hardness test less than a 36 Rc.
Stroking these cranks is doable, but should remain a job of a shop with experience and the knowledge to get it right.
Never exceed 325 rpm when you balance the crank. There is enough mass there to whip the crank around and change it on the machine.
Do not use bob-weights. The stock throwing index provides inherent balance already.
Many of the high powered engines also have a shot penned fillet area. If you grind it away with stroking or just undersizing the journals....you have to re-peen that area again. Not all shot peening is the same. Be certain it is done by a shop listed by Cummins. There are only 10 in the country. These shops have been provided the proper shot and process guidelines to do the work the correct way. If yours is not shot peened in the first place....you have not to worry about getting it done at all.
Don~
Don~
Thanks for the info, Don. Are these issues that a crankshaft builder will need to take into account when building a billet crank? i.e. should the stock "fillet radius used on the flange" be stronger than an aftermarket fillet of different radius, if you're starting from a blank billet, or are you speaking with regards to offset grinding the stock crank?
When you say "Stroking these cranks is doable, but should remain a job of a shop with experience and the knowledge to get it right. " Do you mean its physically possible to build a crank that is stroked, or that it can be made to run well? Do you know of any shops that have experimented with increasing the stroke on the Cummins B?
Thanks again for all the info, everyone!
Chris
Chris
Originally posted by GO 4LO
Hohn, what do you think about Crower and Scat billet cranks? Do you have a web address for Winberg?
It seems that with a lighter billet crank, lighter rods and pistons, lighter flywheel, lighter driveshafts, lighter wheels and tires, we could drop 300 lbs of rotating weight off of one of these trucks. But no one has done it yet? I'm hoping it's due to cost and not just because it's a stupid idea .
Chris
Chris
The Winberg cranks are used by the biggest name NASCAR, Pro Stock, Top Fuel, teams etc. It's big $$ to get them to do your work.
Henry Velasco is the only other crank "guru" that I would look up for a serious high end project. I know there are a lot of talented crank grinders out there, but Velasco and Winberg are among the most respected, if not them most.
Loopy and jet-lagged in Germany,
Justin
I didn't mean to offer those two companies as an alternative to Winberg. It's just these are the only two companies I've been able to find on the internet that will custom build a billet Cummins crank. Do guys like Winberg and Velasco do one-off work, or is it more like they're each associated with a specific nascar team and only do work for them? Thanks again for all the info, and if you want to wait till you get back Stateside to answer, I guess that'll be okay.
Chris
Chris
DTR Advertiser
A custom crank grinder might just grind his own fillet radius and match that to a set of bearing that would be custom as well.
The Cummins fillet and bearing design are IMO the best way to go.
A one off crank is not cheap. To forge something like that will cost in the "hood" of probably 5000 bucks or more.
Not all forged cranks are alike either. Some are forged and twisted into shape. Twisted cranks are generally weaker than a crank that is forged into shape.
The stock Cummins crank is a sweet piece. Its forged and stronger than you might think.
So given all this info above, what would be the ideal setup for a dragracing (and occasional sledpulling) Cummins:
Displacement numbers assume 10thou overbore.
4.37"___5500rpm___334cid___1.75
4.52"___5250rpm___346cid___1.69
4.72"___5100rpm___361cid___1.62
4.92"___4900rpm___377cid___1.55
Not sure how to calculate the differences in cylinder wall loading between these setups, though. Any help?
Chris
Chris
By the way, the number correspond to a 4000 fpm max piston speed and were originally calculated by Missouri Mule in a previous bore/stroke post.
Chris
Chris
Chris
Chris
Picture a right triangle where the crank stroke is one leg, the piston height is another, and the rod is the hypotenuse. If cyl pressure is 2000psi, then you divide by the piston surface area to give you the FORCE acting down on the piston. At a 15°, 96.6% of the piston's downforce acts along the rod. The remaining 3.4% goes into the cylinder walls as friction's normal force.
This is just the Cosine of the angle between the rod and the bore centerline.
At 25°, the side loading goes from 3.6% to 10%.
At 45°, it's 29.3%
At 60°, it's 50%!
So you can see how it rapidly gets REALLY bad as you get into the extreme rod angles I don't think that any engine uses an angle over 35°, but I could be wrong.
Short rods cause more wall loading.
Justin
To visualize loading, picture a sine wave with 90° at the top and 0° at the bottom. The rate rapidly passes from one extreme to the other. You'd think that the 50% loading point is 45°, but it's not-- it's 60°! 45° is still 71% of your initial value (or conversely, 29% loading).
Or visualize the "bell curve" that you've seen before, representing a "normal" distribution. It's also similar. As you head towards the extremes, things change drastically.
jlh
jlh
JRAPTOR04
23
10-21-2007 01:57 PM
