i want 500 rwhp!!!
Old 09-06-2007 | 02:54 AM
powermad's Avatar
i want 500 rwhp!!!
so im starting to get passed the chip exhaust intake and turbo stage im guessing im putting out maybe 380hp im planning on putting in 125hp injectors and a water meth kit from snow performance. my turbo is a edge jammer bb, will i be able to get 500 hp with this setup
Old 09-06-2007 | 02:56 AM
dodgediesel's Avatar
Not with that turbo but yes to everything else. Go with some Mach 4 injectors. Best $900.00 i've spent on my truck...
Old 09-06-2007 | 03:22 AM
HOHN's Avatar
+1 on the Mach 4s. Most 125hp injectors are too small to show you to 500hp.
Edge Jammer won't show you 500hp-- at least not more than a few times without turning into a grenade (just my belief).
For 500hp, I'd go with a 64mm-66mm class turbo if you are staying with single turbos (I'm assuming no twins). Bigger housing will make it easier to make the number, but the lag might make towing tough or impossible. Try a "14" housing (whatever the heck that means).
I'm toying with trying a Garrett GT4088-- somewhat laggy, but should pull really strong up top. I don't tow much at all, but I'd like to be able to pull small loads with the need arises, so I'll have to see if this is realistically an option.
For more than a quick flash over 500, you'll want to consider a cam and some airflow enhancement (porting perhaps).
Justin
Old 09-06-2007 | 05:02 AM
jwb600's Avatar
I know of a local truck that made 620hp on a dyno with the following:
aurora 5000 turbo
huge injectors
edge drag comp box
hot rod vp44
fass pump
the engine is stock inside meaning NO cam, springs, head work
Old 09-06-2007 | 06:12 AM
Texas Cowboy's Avatar
Know that Bob Wagner has 4's and Smarty made over 500 I believe. Sure I read that somewhere. ??
Old 09-06-2007 | 07:18 AM
1qckdodge's Avatar
496/989 with Stg 5 Jammers, PS62, and a Van AAken TST Comp stack, 511/1166 with Mach 6s Drag Comp and the same PS62, Now I have a Silver Bullet, ARP studs,Cometic head gasket, Mach 6s, Van Aaken and a TST PM3, so we will see what she does now, so far the first combo was sweet, that 496/989 was an awesome daily driven combo, it was even nastier when I added my Catcher to the mix and removed the Van Aaken, dont really worry about the hp to the grown, its all about driveability, a laggy smoky daily driven truck is no fun, good luck.
Old 09-06-2007 | 09:30 AM
pmtg's Avatar
nope, it was 400.
i wish 500 was possible without tapping the wire .....not yet atleast.
Old 09-06-2007 | 10:31 AM
Mike D's Avatar
507/1042 with 4.5s and a 64/12
Old 09-06-2007 | 10:33 AM
getblown5.9's Avatar
Its easy to hit 500hp with one of these trucks, just ask some of the experts around here who will tell ya their truck only needs this and that to hit 500...
Or you can ask the guys who have been trying for 2 years to break 500hp and can only get within 3hp of it how hard and expensive it is
Old 09-06-2007 | 10:45 AM
CTD01's Avatar
Pump
Do you still have the HO pump might be making it alot harder
Old 09-06-2007 | 11:00 AM
I dont have an HO pump and I have been over 500hp for awhile now
Old 09-06-2007 | 11:10 AM
Ph4tty's Avatar
Yes there are several of us with BBS I think I'm just a good dyno run away, for for now I'll just be happy with my 400ish hp truck.
Powermad, you might want to look into some studs or having your head o-ringed before playing with drugs.
Old 09-06-2007 | 11:27 AM
Mike D's Avatar
I know I stuggled with reaching 500hp. Playing with the Smarty and setting the wastegate was the biggest issues I faced.
I made my best HP with around 46-48 lbs of boost using a boost elbow. When I dyno'd with the wastegate set to HTT specs (40 lbs) it made 475.
Old 09-06-2007 | 01:09 PM
timbeaux38's Avatar
Call Turbonetics and get a price on upgrading your Jammer BB to a T-61.
Old 09-06-2007 | 01:57 PM
seabee's Avatar
i agree call turbonetics. but the wheel on the t-61 is not what you want the one to talk to them about would be the t-66 is by far a better wheel.
