I Think I Need More Fuel Pressure
I pulled my gauge down to 8psi at WOT, thats with Vulcan big line and stock LP, Will a holley blue keep me above 10 psi at WOT if I stack a TST with the EZ and Jammer III's.
What are some other options as far as pumps?
P.S. .....Cant afford FASS!!!
Well I relocated the LP back at the tank so thats outta the question I think. When I first put the relocation kit in I could get it under 10psi, Im starting to think that my LP is on its last leg.
Thanks,
Jamie
Thanks,
Jamie
Dont see why you couldnt run the blue with the in-tank LP, Just plumb it in-line between the fuel tank and IP. If you decide to do something in the near future let me know, I would be happy to help out, I'll be up that way in a week.
I'm at 11 psi WOT with stock injectors. I'll probably check the fuel tank to fuel line connector after better injectors...somebody said the connector has a small opening.
I may give you a call caleb. I had a lovely dead pedal incident this morning so bad things are coming.
I can just run a blue where the LP is right?
Will the blue flow more than a stock LP, it should right?
rossco
08-23-2007 06:17 PM
